VideoHelp.com Forum
  1. Hi everyone
    I have burnt my first SVCD yesterday (converted AVI to Mpg2 through tmpeg) and then created a menu with a picture in background and the titles of the mpg ) when I preview the menu in NEro before burning I can see the picture and the links no probs but when the svcd is burnt and played on my home DVD player the menu doesn't appear and can only play my mpgs!?
    does anyone know why it's not showing ?
    Please help !
    Thanks in advance
    Fred
    It could possibly be that "PBC" is not enabled on your DVD Player, check that it is and then play the disc.
  3. Thanks for your reply Banquo!!
    However what is a PBC and how do you activate it on the DVD player is it through the menu?
    "PBC" = Playback Control (I Think), it allows interactive elements (ie a menu) on a (S)VCD. You normally can dis/en-able it by a button on your remote, although obviously dvd players vary.
    If it still doesn't work, it could be how you authored it in Nero. I haven't used Nero to author discs for a long time, VCDEasy is much better and as this is supposed to be a VCDEasy forum perhaps you could see if it works when you author it with VCDEasy.
    You'll find everything you need (software, guides) within this very site, good luck.
  5. Note: Some DVD players are not capable of displaying menus on (S)VCD's. Check your DVD model under the OTHER - DVD Players selection on the left of the here.
    Stella
  1. Why won't the Xbox 360 playback .mp4 video
    By smitbret in forum Media Center PC / MediaCenters
    Last Post: 13th Mar 2012, 02:34
  2. multiAVCHD won't create main menu
    By The Realms of Gold in forum Authoring (DVD)
    Last Post: 21st Mar 2011, 11:48
  3. Menu button won't highlight
    By mattblack in forum Authoring (DVD)
    Last Post: 21st Oct 2010, 17:45
  4. My new capture card can record and playback, but won't live stream. :-/
    By Deadlight7 in forum Newbie / General discussions
    Last Post: 30th Jun 2010, 23:50
  5. Win Media Player won't playback mpeg video
    By Borgatt in forum Software Playing
    Last Post: 21st Jun 2007, 02:46
