I am trying to capture via S-Video from my digital cable box to my Hauppauge WinTV(PCI), but I am getting something a friend called a "ground loop" problem. I am not entirely sure what causes it, but it results in the picture being a bit wavy and the audio gets a slight hum.
I am no expert on ground loops, but I understand it can be tricky to deal with. The thing is, I don't get the problem when I connect the digibox to my TV, and I can capture from VHS without any problems. I am wondering if my PC might not be properly grounded, since my TV doesn't have the problem, but I am not sure how to find out of it is grounded or not. The humming disappears if I unplug the TV cable going into my digibox, leaving just the digibox connected to the PC with no picture.
Any help or suggestions as to how to solve the problem would be greatly appreciated.
There is another post about this type of thing from about a week ago. That thread has an answer for your problem. You should also make the cable company come and fix the problem (assuming that the power in your house is correct).
edit
Got off my lazy behind... here is the thread http://www.vcdhelp.com/forum/viewtopic.php?t=136151Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Thanks for the link. I did actually did a search before posting, but didn't spot that one. Maybe I need to improve my search-skills.
Encore CS4 loop point problem
By sebaz in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Jul 2010, 14:14 -
Problem capturing sky digibox recordings
By scamperoo in forum CapturingReplies: 9Last Post: 19th Oct 2009, 09:32 -
How to filter out a ground buzz
By pdx10 in forum AudioReplies: 4Last Post: 24th Mar 2009, 09:14 -
Ground Loop problem. Subwoofer hum. Will this gound isolater work on HD
By Denvers Dawgs in forum DVB / HDTVReplies: 3Last Post: 16th Jun 2007, 23:43 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum CapturingReplies: 5Last Post: 16th Jun 2007, 03:03
Statistics
Newest guides
Latest tool updates
New media comments
