VideoHelp.com Forum
    Hallo.
    everytime I create the mpeg file I use the same settings
    so it is worth for me to save them, but I don't know how to do it in
    TMPGenc.
    I found some files called tamplates, which seem to contain
    saved config of TMPGenc, but I don't know how to save my config into such template.
    Maybe You know
    greetings
    Maciej
  2. Member JamieBecks23's Avatar
    Er..the Save button next to load and setting?
  3. evening pikpus,
    Just another tip.. when you do save a template, NOT everything is
    setting's wise) is saved. Some settings revert back to TMPG's default
    state (or behaviour) and also, depending on which version, some things
    may or may not act the same when you do save as a template.
    But, most everything else will save though. Filters don't save. But, when
    you close down TMPG, and later, reopen it, the LAST set of filters and
    thier respective settings are still intact. So, that's good knews. But, at
    the same time, you have to be watchfull for this, cause you don't want
    to apply those same filters on a better "source material" -- pending on
    your source, of course.
    So, basiclally, you have to play around w/ the Templates and see what
    gets saved, and go from their. But, I wouldn't worry about it so much.
    You are more than likely not to have any problems using Saving Templates.
    -vhelp
    Thank You guys for Your help
    Maciej
  1. TMGEnc Xpress - no sound
    By deanst2 in forum Authoring (DVD)
    Last Post: 2nd Jun 2010, 17:27
  2. TMGEnc Xpress Not enough memory issue
    By hawk123 in forum Video Conversion
    Last Post: 10th May 2010, 18:21
  3. Howto 4:3 movie save to 16:9 format
    By eMCe in forum ffmpegX general discussion
    Last Post: 16th Feb 2010, 13:27
  4. Router config (D-link)
    By SE14man in forum Newbie / General discussions
    Last Post: 9th Dec 2007, 07:12
  5. Tmgenc DVD Author
    By powerkoala in forum Video Conversion
    Last Post: 19th Sep 2007, 06:02
