i've tried ripping "the matrix" but whenever i do the picture seems squished together a bit as if i'm converting ntsc to pal. i'm wondering if theres a way to fix this. the picture is fine when played on a dvd player
Results 1 to 10 of 10
Thread: smartripper rips bad resolution
i've tried ripping another movie and theres the same problem
here are the settings i used - http://us.share.geocities.com/metall...3/untitled.bmp
you have to save the pic
i think maybe the problem is with you, not the software. smartripper only rips the files. it doesn't convert them.
i opened the vob files with DVD2AVI and it shows the movie distorted there. i thought this was just a problem with the DVD2AVI preview window but when i convert in tmpgenc, the movie is still squished. anyway to fix this problem?
thanks for trying to help, but my problem is that the video is already widescreen, and it seems that its squished from left and right. i dont think i'm doing anything wrong with tmpgenc because it already seems off when i preview it in DVD2AVI or watching the vob files with windows media player
its supposed to do that. the source is 16:9. so it looks stretched vertically. in tmpgenc under advanced choose the source as 16:9 and the aspect ratio as full screen (keep aspect ratio).
I assume that you mean it looks squished on your PC. That's normal. The problem here is with DAR (display aspect ratio). There are 3 main ones that we deal with:
1:1 for PC
4:3 standard TV
16:9 movies (and some/most HDTVs)
If you take a 16:9 DAR source and try to watch it (without resizing) on a 1:1 DAR PC monitor it will NOT look right. However, if you just go ahead and (correctly) encode it will play fine on your TV.
Take a look at http://www.doom9.org under "The Basics" there's an article there called "aspect ratios explained" I'd give the full link but the site seems to be down right now
Ideal Size and Resolution HDTV for typical avi/mkv rips?
By Danteism in forum DVB / HDTVReplies: 3Last Post: 25th Nov 2011, 06:51 -
VLC player - bad vertical resolution
By igorek in forum Software PlayingReplies: 4Last Post: 15th Sep 2010, 17:39 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Which is Best Resolution for 1CD DVD-Rips
By mani4frenz in forum DVD RippingReplies: 11Last Post: 28th May 2009, 08:53 -
DVDFAB bad quality rips
By kidcash in forum DVD RippingReplies: 16Last Post: 19th Sep 2007, 02:46
