VideoHelp.com Forum
Results 1 to 9 of 9
  1. I have an avi movie that is in synch and plays perfectly fine, but when I convert it to mpeg2 to make an SVCD, the audio gets slightly out of synch.... what can I do to get the mpeg2 file back in synch? (I've only been able to find guides on how to fix audio synch for avi's, but not for mpeg2 files... pls help
    Try running it through Tmpgenc Simple Multiplex, before burning with Nero.
    Works for me!.
    where's the sync prob? in your PC or on your DVD player (mine takes a sound delay of 500ms to sync properly)
  4. could you pls explain what you mean by multiplex... I'm really new to all this so could you explain the steps... thank you
  5. the sync problem is on my pc, when I open the mpeg2 file with powerDVD,the audio is out of sync...I haven't tried burning it on CD for my DVD player....what do u mean 500 ms..
    u sure that the avi is in sync all the way through before converting? Have u saved the sound as uncompressed wave and interleaved to avi before processing? (ignore the 500ms that sound sync I mentioned that is specific after burning to vcd for my model of dvd player)
    you know it's the anti-Midas touch when all you touch goes to shit..............
  7. okay
    encode whit tmpgenc
    go to source range and select only a very small segment to encode
    (when you see a dialog in the movie)
    and try to calculate the time of the synch error by conting betwenn you see a door clap and when you hear it
    and 1 second is 1000milisec
    try some value in the audio gap corect window under the source range window
    try many value and you will find the corect fit
    to forward the time insert the - before milisec
    ex. forward 15000
    backward -15000
    NO!, if your going to do that do it in virtualdub, go to audio interleaving and put figures in for audio delay, then press play in virtual dub. Will see results before encoding. No need to do encoding of small bits of movie to see results
    - u shouldn't be getting probs for sound sync if u have followed the guides and have it synced as an avi, wot sound format u inputting to TMPG? wot fps u going from and to?
  9. A TIP FOR YOU:-
    There is a program called Decompressor which you can find in Avi 2 VCD. What the problem is that your Audio is compressed. Even though the .AVI plays perfect on your PC it won't on your VCD/DVD player or whatever you have when you convert it.
    The reason your getting the problem is that TMPGEnc doesn't process Compressed audio AVI;s too good so you will Decompress the audio of the file using the program..Im trying to explain it to you as simple as I can because I had to go through that also. So next time when you are about to encode an AVI make sure you decompress the audio. Since I figures it out I really have never had a problem. I hope you understand.. hope it helps...The program is very very Easy to use..try it out..
  1. audio sync problem, how to work out progressive audio sync delay
    By jolt321 in forum Newbie / General discussions
    Last Post: 10th Apr 2012, 21:09
  2. Sony DVD Arch4, audio problem, pls help
    By jazu in forum Authoring (DVD)
    Last Post: 20th Nov 2009, 17:14
  3. Audio Sync Problem
    By lwea2009 in forum Newbie / General discussions
    Last Post: 30th May 2009, 15:19
  4. out of sync audio problem
    By virendra in forum Audio
    Last Post: 25th Dec 2007, 06:31
  5. New (?) audio sync problem
    By oldblues in forum ffmpegX general discussion
    Last Post: 26th Oct 2007, 10:26
