VideoHelp.com Forum
  1. I have Perfected my DIVX to DVD conversion but when i try to do the same method for XVID i run into problems when extracting audio with Virtual DUB
    when i try to extract audio from an XVID using Virtual DUB i get the following
    The requeted audio compression is not compatible with the input format
    why is this i am trying to extract the audio with no changes (48000) so i can import in TMPEnc~
    Thanks in advance
    MAC
    It is probably AC3. You can use gspot to identify the audio source.
    www.vcdhelp.com/tools#other
    and if it is AC3
    http://www.vcdhelp.com/forum/userguides/91588.php
    or it might work to open the xvid with ac3 directly in TMPGEnc if you have an ac3 codec.
  1. DVD to XviD Conversion
    By DJRumpy in forum User guides
    Last Post: 7th Mar 2011, 16:37
  2. Replies: 1
    Last Post: 26th Feb 2010, 08:12
  3. Check Over My Options From DVD to XviD Conversion Thread
    By adalect in forum Newbie / General discussions
    Last Post: 9th Feb 2010, 20:24
  4. dvd to xvid conversion problem
    By dominator007 in forum DVD Ripping
    Last Post: 19th Nov 2008, 15:33
  5. Xvid to DVD conversion
    By Meriks in forum Authoring (DVD)
    Last Post: 5th Apr 2008, 10:43
