VideoHelp.com Forum
Results 1 to 13 of 13
    Hey. I am right now really pissed off. I've always used Tmpegenc for DVD-SVCD conversion. I converted X-men using CQ 2500 kbps and quality 65 which gave me excellent quality, no singe macroblock whatsoever.
    BUT, now, I am trying to convert just one scene with a lot of movement from Terminator 2 (the scene where Sara's dreaming about her own death, when a nuclear bomb explodes and scatters her and a city, and some playing kids), just because I know this scene has a lot of movement, yeah.
    Anyway, I tried the same settings as I've used before, and I get hell of a lot of macroblocks! The fastest action scenes in X-men didn't have ANY blocks and it was crystal clear, crisp and .. just excellent.
    So I even tried raising the quality to 100 and used motion estimate blablabla highest quality, but that didn't work either. I even raised the bitrate up to 3000 kbps .. but there are still macroblocks. OK, not as much as before, but they're there, and I think it's really strange since X-men didn't have any at all, and there are many action scenes..
    What am I doing wrong!?
    try cce ..just encoded the whole movie in SVCD on two disks...and there is not a single macroblock to be seen anywhere...:d
    <font size=-1>[ This Message was edited by: nsdn on 2001-09-02 23:48:41 ]</font>
  3. What other programs do you need to get your ripped dvd ready for CCE?
    decoder: dvd2avi
    filter and frameserve: AVIsynth or VirtualDub
    video encoder: cce
    audio encoder: tooLAME
    multiplex: bbMPEG
  5. Let me add that you might want to try TMPGencs 2pass VBR at a high bitrate OR CCE's multipass VBR. Normally if I'm doing something in CCE I really like I'll set it to 3pass VBR. If you're only doing a short scence you can try 4pass (or what hell even 5pass )
    Yeah I tried CCE, used 4-pass VBR and there were terribly much macroblocks..!
    I was using 2.5 SP or something.. perhaps the latest version is better?
    Latest version 2.62 isn't better, but it doesn't matter because v.2.50 is superb.
    Something you are doing wrong, sure. You may post the details, maybe someone figure it out.
    OK. Source is DVD - Terminator 2 special edition
    It's 15 seconds, a scene where Sarah Connor is dreaming about the future, when she gets blown up by a nuclear bomb along with some playing kids.
    That scene has lots of motion.
    (clad DVD for ripping DVD)
    DVD2AVI to make a dv2.. used force film.
    I don't remember what the program's called, but it makes an avi out of a dv2.
    Then I used virtualdub to frameserv, using resize (480x480).
    Loaded the avi into CCE 2.5 SP.
    I used 4 pass VBR, 3000 kbps max bitrate (yes! I even used a higher bitrate than SVCD standards and there was lots of blocks). I don't remember what the average bitrate was but quite high...
    Hm I think that's all I can remember, does anyone see any obvious mistakes that could have made the macroblocks disapperar?
    When I loaded the dv2 into tmpeg and used SVCD template (NTSCfilm) CQ 2500 kbps and quality 60 or 65 the quality was a LOT better, but there were still some macroblocks...
    Everything seem to be OK. I don't know, what is wrong here.
    However, I converted T2 to MPEG-2 480x576 VBR 4pass 1530kbps (min 1000, max 2450) with cce sp 2.50 and got very good quality, no macroblocks at all. Sorry, I have no idea.
    Well.. hmm OK I suppose trying again wouldn't hurt? Using your settings.
    But the minimun bitrate.. is there any point of setting it to 1000? (couldn't it be 0?) Just asking.
  11. Member kreg's Avatar
    I'd like to try cce 2.5, but I can't find it. Any suggestions?
    _________________
    ICQ = 162352
    IRC = #ds9 (irc.openprojects.net)
    email = kreg@linif.org
    <font size=-1>[ This Message was edited by: kreg on 2001-09-07 06:55:22 ]</font>
    Maybe you could check out http://www.vcdsp.com downloads section you might find something you want there....
  13. Member kreg's Avatar
    Hmm
    Nope, seems to be a dead link tonight. I guess I'll just get it from you. Please email me 2.5 so I can use the framserver from VDub. I can't seem to find the trail version or any version of 2.5
    here is the email address.
    Thank you much.
    _________________
    ICQ = 162352
    <font size=-1>[ This Message was edited by: kreg on 2001-09-08 01:19:36 ]</font>
  1. H.264 macroblock sizes
    By grinder_luck in forum Programming
    Last Post: 13th Jul 2011, 08:26
  2. White Screen in TMPEGEnc 4.0
    By barrylay in forum Video Streaming
    Last Post: 1st May 2011, 15:09
  3. H.264 Flexible Macroblock Ordering
    By krao in forum Programming
    Last Post: 2nd Dec 2009, 23:39
  4. AVC/h264 1080p mkv macroblock problem on sequence transition
    By djesteban in forum Blu-ray Ripping
    Last Post: 7th Oct 2008, 09:18
  5. TMPEGENC keeps closing itself because of an error
    By Akhet in forum Newbie / General discussions
    Last Post: 14th Oct 2007, 00:38
