VideoHelp.com Forum
  1. Was wondering if ANYONE got the samsung DVD-611 (US Version) to play a VCD?? and if so, how?? I've made 4 coasters so far... please help!
    -Brandon
  2. I had a samsung 709, it only played standard vcd and svcd but it was very funny with the type of media it used, I could only get vivastar disks to work (UK) with a light blue bottom. So try and get hold of some CDR with a light blue dye and see what happens.
    I dunno...it might work
  3. Member bugster's Avatar
    I USED to own a Samsung DVD-511 and it would play VCD's on CDRW only, NOT CDR's
    Hope this helps.
    I had a Samsung 709 and yeah it seems very picky about the media it uses. Blue Dyes such as the ones found on Princo Discs worked perfectly on them though.
    I have the Samsung M301 and just got the samsung P421 for my mom. Media is a big problem. I switched to ACCU (purple/silver DVD-Rs) and have made no coasters since. I am making dvds though, not vcds.
    Also, I switched from using Nero to RecordMax for my burning software since Nero always made coasters too for me.
  6. I have a Samsung DVD-611 (European version tough) and it will play anything I toss as it.
    Maybe you could change to a European firmware revision?
  1. Samsung HT-C450/XEU & Samsung BD-C5300 hacks/codes needed
    By raindancerob in forum DVD & Blu-ray Players
    Last Post: 5th Mar 2011, 10:45
  2. Samsung VR350. Can't play DVD anywhereelse but in Samsung VR350
    By gux70 in forum DVD & Blu-ray Recorders
    Last Post: 21st Aug 2010, 09:34
  3. Samsung BD-P1590 VS Samsung BD-P1500?
    By Darkerknight123 in forum DVD & Blu-ray Players
    Last Post: 3rd Jan 2010, 16:51
  4. Samsung HT-Z210, Samsung HT-X250
    By emmy207 in forum DVD & Blu-ray Players
    Last Post: 28th Mar 2009, 22:06
  5. Stand Alone Samsung HD Tuner vs. Samsung DVD Burner/Tuner
    By MacPCConsultants in forum DVB / HDTV
    Last Post: 7th Jun 2008, 01:42
