i have a Celeron 700mhz system with windows XP and ATI all-in-wonder128 video card.
i can capture at 352x240 MPEG1 without loss, but anything higher drops frames
i want to try and capture at 720x480 or at least 480x480 MPEG2
can anyone give me some help with this?
pickman_2000@yahoo.com
Cal Rankin (The Mimic)
Try upgrading your MMC, 7.6 should work with that card and OS. Also, it helps tremendously to capture to a different hard drive than your OS is on.
One other thing that may help is to capture Cropped Video, this cuts the overscan area and makes the res 672x448 when set to 720x480.
Try working your way through the "How to Tune your system for ATI capture cards" guide, here:
http://www.vcdhelp.com/forum/userguides/81808.php
It should help some and it may eliminate most if not all of your dropped frames.
Your "Celeron 700" may not be able to handle 720 x 480 without significant dropped frames, especially encoding directly to MPEG-2 format. If after going through the guide listed above you still have a significant amount of dropped frames at 720 x 480 resolution, you may want to try caputuring directly to avi fomat and encoding to MPEG-2 format after the capture is completed.
Dropping frames on New PC
By beammeup in forum CapturingReplies: 9Last Post: 16th Apr 2012, 11:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
Please help me stop dropping frames!
By justin81 in forum CapturingReplies: 28Last Post: 1st Apr 2011, 07:17 -
VirtualDub Dropping Frames when capturing VHS
By big_al_40 in forum CapturingReplies: 8Last Post: 4th Jun 2007, 15:57 -
Capturing problem.. Dropping frames..
By azazel_dx in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 13th May 2007, 14:47
Statistics
Newest guides
Latest tool updates
New media comments
