VideoHelp.com Forum
  1. I just bought a DVD-R Burner. I just wanted to make sure that laptop DVD Drives support DVD-R.
    My Laptop is a Toshiba Laptop and my DVD Drive is a Matshita SR - 8176.
    Any ideas? Also is there a site that tests compatibility of DVD Drives?
    Thanks.
  2. Member bugster's Avatar
    Many existing DVD ROM drives (laptop or otherwise) do NOT support DVD-r, though many newere ones do. In my experience its largley a matter of luck and age of device as to wether support is present or not with more luck required the older the drive!
  3. I know that my drive does support DVD+R. Does this mean that it should support DVD-R, since DVD-R is supposedly more compatible?
    Thanks.
    Thanks.
    DVD+R and DVD-R (not RW) have similar degrees of reflectivity - barring hardware prohibitions, any drive new enough to read the one can typically read the other.
    DVD/RW are typically somewhat less readable in legacy drives.
    -MPB/AZ
  1. Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
    By MeekloBraca in forum DVD & Blu-ray Writers
    Last Post: 9th Dec 2009, 02:27
  2. Do laptop dvd drives play in progressive scan?
    By ieh4f in forum Newbie / General discussions
    Last Post: 29th May 2008, 19:36
  3. Can my Laptop support TV Out?
    By soneman in forum Software Playing
    Last Post: 15th May 2008, 11:17
  4. Laptop DVD Burner suddenly only burns small portion of DVD
    By hydrurga in forum DVD & Blu-ray Writers
    Last Post: 13th Feb 2008, 03:39
  5. connecting laptop to PC and using both DVD drives
    By debrag in forum Media Center PC / MediaCenters
    Last Post: 4th Oct 2007, 11:20
