I bought this Sony for the simple fact that it said it supported 4x burn speeds on DVD-R which should translate to 15min burns.
What I've seen on these message boards is that the drive does really go 4x... it still takes about 30 minutes to burn a DVD-R.![]()
has anyone gotten the Sony to burn 4x (15 minute burns) ??
Results 1 to 9 of 9
Originally Posted by mimo330ci
I GUESS NOT.
What is your cpu usage like when burning? I will comfirm my finding later tonight...have to be somewhere now.
That's what attracted me to the Sony, but at $3 a piece on the 4x media maybe it's not that important. That's what Meritline has the media for but I don't think the price difference is worth it. I've burned at 2x with Memorex DVD-R v2 and Accu and Ritek as well. If the price comes down on the media I might look into it further, but for now I don't think it's worth the 15 minutes of time savings. Besides, there's always something to be busy with for the 15 minutes.
I don't think this answers your questions but if a DVD+R is $2.85 for 2.4x and a DVD-R is $3 for 4x...is the extra 1.6x worth 15 cents? If indeed you're really going to burn at true 4x?
Besides, that's Nero's rated speed, at least in my experience and not too accurate. I burn at 2.4x in about 26 minutes.
Let's see if anyone responds.
Send me one. I'll test it
Just kidding, but this is I think like 4th post that is asking the same question.
At this point I'm not even looking at the price issue.Originally Posted by heretic422
I bought a Sony burner that claims to do 4X, but from what I'm hearing..... it DOESN'T.
That's like buying a Ferrari that comes with a Honda engine in it.
mimo330ci, I would not try Ferrari with some very cheap gasoline.
Try some branded 4x media. Not meritline. And I am not saying that Sony is not the problem.
See this post CPU usage.
Yeah I would have to agree, since 4x media is pretty new you would probably want to try the best of it for now.Originally Posted by donpedro
To original poster:
Also other things can factor into your burn speed, before I moved my DRU500A over to a Windows XP box I have setup, I was getting like 1 hour and 15 minute burn times under 98SE (at 1x). Nothing I could see could explain why, my transfer rates were higher then my XP box HD's (SCSI 15K RPM'S in the 98SE box) When I moved it over to XP, then my burn times for 1x media were at the proper 1 hour mark.
Now I only burn 2x Ritek, that seems to be the sweet spot in time vs $$ at the moment. 30 minutes per disk. When 4x media is what 2x is currently at, then I will move to that..
I highly doubt Sony would make a burner that they say works at 4x that does not. You might have stumbled onto a bug or something since 4x media is so recent.
Good luck.
Media does not burn at advertised speeds.
By nick101181 in forum MediaReplies: 14Last Post: 27th Feb 2010, 16:44 -
Burn DVD / Divx for SONY DVP-NS708H
By yan_pap in forum MacReplies: 3Last Post: 5th Apr 2009, 05:58 -
Extremely low burn speeds, High CPU usage
By BetaMaster in forum Authoring (DVD)Replies: 13Last Post: 20th Nov 2008, 12:23 -
relative quality and best burn speeds for some popular media
By JohnnyBob in forum MediaReplies: 32Last Post: 8th Feb 2008, 17:44 -
Can't get rid of PIO, Slow burn speeds
By ER_Doc in forum DVD & Blu-ray WritersReplies: 9Last Post: 19th Jul 2007, 22:28
