VideoHelp.com Forum
    I have been using vcdgear to convert .dat(vcd movies) to mpg format regularly.
    Problem that I have just encountered is:
    vcdgear fails to open the .dat file in the mpegav folder so stumping me from converting it.
    It says it cannot open it.
    It does not happen on every disc.
    It seems to be very unpredictable, also removed and reinstalled it but to no avail.
    Would it be possible it was the way the original was produced(software)
    Any ideas--------- y`all
    If tomorrow doesn`t exist where shall we all be the day after tomorrow!!!!!!!!!!!!!!!!!!!!
  2. Maybe it's the disc, have you tried copying the .dat to the computer just to make sure it's readable? There is also other tools to do that.
    Never thought of that.Will try cheers.
    Is there any other dat to mpg converters that u know of?
    I am a dumbass.
    Copied it to the hd no probs and vcdgear converted it fine.
    Cheers for the savvy adjustment crahak
    You can use IsoBuster.
  1. MKV2AC3 query on file size change?
    By boredandilliterate in forum Newbie / General discussions
    Last Post: 15th Dec 2011, 15:54
  2. DAT/MPG to VOB/MKV?
    By coxanhvn in forum Newbie / General discussions
    Last Post: 30th Jan 2011, 05:21
  3. Query: Best way to go from a cda. file to plain PCM is ??????
    By Canon GL-2 Guy in forum Newbie / General discussions
    Last Post: 22nd Jun 2010, 20:46
  4. VOB File and CD overburn Query
    By scott274 in forum Newbie / General discussions
    Last Post: 17th Nov 2009, 01:54
  5. Best AV file analyzer query/poll
    Last Post: 23rd Jun 2009, 16:17
