will pc100 ram work on a pc133 mobo?
If the processor you are running has a FSB of 100mhz, then yes.
However, if you are using a processor with a 133fsb i'm not sure b/c I delved to deep into overclocking ram. If I needed faster ram, I'd go out and get it.
But then again it may work in Asyncronous mode.
If it is high quality pc100 it may work, but if it is low quality, usually the bargain ram, it will very well not work. It would probably cause many lock ups, etc. All I can say is try it. But pc133 is as cheap if not cheaper so you might as well get it if you are using a 133mhz fsb processor
Yes. You only need to change the latency of the memory. Press del during boot up and increase the memory latency . Of course the performance can't be as good as PC133 but at least it is still working until you have money to upgrade.Originally Posted by bboy486
Cau
Ram recommendation for amd cpu & biostar mobo combo?
By Stealth3si in forum ComputerReplies: 27Last Post: 11th Feb 2012, 12:05 -
Gigabyte Mobo, Input/opinions needed... & a Q on ram for new build.
By Noahtuck in forum ComputerReplies: 12Last Post: 28th Aug 2011, 07:30 -
Value ram
By jollyjohn in forum ComputerReplies: 19Last Post: 5th Mar 2011, 06:21 -
RAM!!
By HotDamn! in forum ComputerReplies: 14Last Post: 15th Dec 2009, 07:43 -
more ram?
By Heywould3 in forum ComputerReplies: 7Last Post: 24th Jul 2007, 11:32
Statistics
Newest guides
Latest tool updates
New media comments
