VideoHelp.com Forum
    When i try to burn this cue and bin in nero it comes opens this window "Foreign image settings" I press ok but it opens a window saying,
    The entered block size does not correspond to the image length. The block size may be wrong. Do you want to correct the value or ignore the problem?
    Never seen this before so don't know what to do could you help?
    The best way to predict the future is to invent it.
    did you generate the bin/cue yourself?
    if not, I would extract your mpeg using isobuster, and then make a new image w/VCDeasy, and then burn it as usual.
    what are you askin' me for...
    I'm an idiot!
  3. Or you could just burn the CUE/BIN image with CDRDAO / VCDEasy if you've already gotten it working!
    Regards.
    Michael Tam
    w: Morsels of Evidence
    Might give VCDEasy ago. Need to download it and set it up 1st,
    How easy is it to use?
    Vitualis gave VCDEasy ago but it would not work on my pc?
    Got the latest ASPI but still no joy
    What about CDRwin? will that run with IDE Writers?
  1. cue and bin files
    By natty in forum Newbie / General discussions
    Last Post: 21st Jun 2011, 15:25
  2. Having trouble with .bin/.cue files
    By UncleBose in forum Software Playing
    Last Post: 12th Jan 2008, 06:06
  3. cue,bin converting to dvd?
    By zziem in forum Newbie / General discussions
    Last Post: 7th Aug 2007, 10:36
  4. What files/settings do I need for bin/cue
    By Choppa in forum Authoring (VCD/SVCD)
    Last Post: 23rd Jun 2007, 21:29
  5. How to merge 2 cue/bin to one DVD
    By motleycool in forum Newbie / General discussions
    Last Post: 7th Jun 2007, 21:26
