When i try to burn this cue and bin in nero it comes opens this window "Foreign image settings" I press ok but it opens a window saying,
The entered block size does not correspond to the image length. The block size may be wrong. Do you want to correct the value or ignore the problem?
Never seen this before so don't know what to do could you help?
Thanks![]()
Results 1 to 1 of 1
The best way to predict the future is to invent it.
Burning problem with bin/cue
By spinaroonie in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2003, 01:29 -
Cue/Bin burning problem
By kingrdr in forum Authoring (VCD/SVCD)Replies: 5Last Post: 11th Jul 2003, 22:05 -
Cue and Bin Burning Problem
By KaNut in forum Newbie / General discussionsReplies: 4Last Post: 4th Jan 2003, 12:04 -
Bin/cue burning problem?
By Jordan02 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 30th Mar 2002, 00:50 -
Problem burning Bin/Cue with CDRwin
By yinki5 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 19th Aug 2001, 15:32
