Can someone explain how im supposed to burn BIN/CUE with NERO? Ive downloaded an SVCD example and im not sure how to burn it so I can see if it works.
Stoked
In Nero, (any version)
You can burn a BIN file by selecting Burn Image under File. Select the CUE file (a text file telling Nero what to do with the bin file), then burn.
If the BIN file was created correctly you should have an SVCD disk.
I did what you said...now how do I test it to see if it works. I put it in my DVD-rom drive and it said windows does not support that file type or CD is corrupted.
Stoked
NOT in any version.
Only in the newer ones. The older versions of Nero 5.5 did not fully support CUE/BIN images and screwed them up if you tried to burn them.
The newer ones are better. I know that my own version (which came with my burner 5.5.8.5) does support CUE/BIN images so presumably, from this version and up should be "okay" (though Nero still has some problems).
You play VCDs on a stand-alone DVD player or on the PC with a software DVD player.
If Windows cannot read your disc, something went wrong somewhere...
I suggest you post more details on exactly what you did.
Regards.Michael Tam
w: Morsels of Evidence
Had problems with nero burning bin\cue files as well way back when
Then I started converting the bin file to an iso file using a program called WinISO
Once the bin was converted to an iso file - nero burnt the iso image fine without any problems using the "burn image" option
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 20:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
