Has DVD2AVI come out with a new version yet that distinguishes between formats correctly? I'm still using ver. 1.74 that may indicate a 16:9 movie as 4:3.
And while I'm here, is there a wav file size difference between 48khz and 44.1 khz audio. I know it takes longer to convert the movie when you have the 48-44.1 check box marked.
One more thing. Is a 1.33:1 full screen move the same as 4:3? How about a 2.35:1 Widescreen movie, same as 16:9?
Results 1 to 1 of 1
Thread: Newer software versions
OEM versions of certain software
By turk690 in forum ComputerReplies: 1Last Post: 2nd Dec 2010, 19:19 -
Newer FFDSHOW versions screw up audio sync for me - why?
By TigerSoul in forum Software PlayingReplies: 7Last Post: 26th Mar 2010, 16:26 -
Free versions of software that expire.
By cal_tony in forum ComputerReplies: 1Last Post: 7th Dec 2009, 13:19 -
Not being able to rip BD with newer versions of DVD FabDecrypter6.2....
By cal_tony in forum Blu-ray RippingReplies: 6Last Post: 13th Nov 2009, 06:47 -
May need newer software
By codeman in forum Newbie / General discussionsReplies: 2Last Post: 14th Nov 2008, 08:29
