ok. wonderwho claims you need to replace the eprom on these with a reprogrammed eprom to take off the macrovision. that macrovision is causing problems for me and i don't even have a vcr connected!
now that's some bullshit.
i've read about updating firmware for the 660 w/ a cdr, but has anyone personally had success doing this? it sounds kind of strange that a dvdplayer would be able to program its own eprom. that sounds like a flash thing.
personal success anyone?
THIS IS HARDCORE
Results 1 to 10 of 10
Thread: apex660 updates w/cdr
THIS IS HARDCORE
I've successfully updated the firmware via CDR on both my 660's and my 703.
i have replaced the chip in my 660-3 to a dual boot chip.
no macro r1 or no macro r0. and all works fine (approx 25.00 us through mail).
the newer 660 can be upgraded through cd-r and i have seen it work...
Can you please post the 660 CDR firmware update procedure or link ?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Depends on what firmware version of your APEX. It it is 660-8-AM or 660-8-MM, your player can upgrade firmware or patch for disable marcrovision and region free via CDR/W.
Check <http://www.nerd-out.com/forum/index.php?f=0>
http://www.dvd-wizards.com/darrenk/660/660patch.htm
http://psych.tripod.com/apexdvdplayers/ad-660hacks.html
Better instructions are at the second link.
Procedure depends on the bios version, but basically once you get the patched firmware rename it to "U660-AM.ROM" (where AM is the Bios version), and burn it to a mode 1 cd and put the file in the root directory. Stick it in the player, it will scan the cd (you might have to hit play) the color of the screen will go crazy as it updates the bios. Then it says Done and pops out the cd. Turn it off and on and you're ready to go.
the link point to a huge forum. Is it possible to point a link to the cdr image file and the burner(??) program ?
hmmm. i have the newer 660 with the outputs on the same side as the play button. (if you call that left or right)
so i can only up/downgrade my firmware once eh?
thanks
THIS IS HARDCORE
THIS IS HARDCORE
Statuspending - the answer to your question is no. You can do multiple updates if you choose. Originally the 8-MM firmware could only be upgraded once but that has changed since the 8-MM has been dumped and hacked.
Sing Sing - it may be a huge site but it will have any answer to any question you may have. If you expend just a minimal amount of effort you will become much clearer on this topic. Do you know how the search function works? Use it and you will have your answers. It can be much easier and quicker to find your answers this way.
Good luck my friend!
<font size=-1>[ This Message was edited by: next on 2001-07-05 11:07:18 ]</font>
How about this one "http://www.nerd-out.com/forum/read.php?f=17&i=1581&t=1581"
Very good and clear instruction but make sure you check your APEX firmware version first (instruction is in that forum also)
Burning SVCDS / Divx to cdr. Which brand cdr is prefered?
By gizbug in forum Newbie / General discussionsReplies: 0Last Post: 18th Oct 2003, 13:52 -
Plain N Simple: How to copy a VCD on a CDR to a blank CDR?
By reddragonmd in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Jul 2002, 16:30 -
GE 1401 plays mp3's and audio cdr but not vcd on cdr....HELP
By sheffie in forum DVD & Blu-ray PlayersReplies: 0Last Post: 14th May 2002, 12:36 -
Daewoo DVG-3000N Updates and hack updates
By cread in forum DVD & Blu-ray PlayersReplies: 0Last Post: 10th Jan 2002, 13:39 -
Apex660 no menus; Pioneer DV525 menus fine?
By leeber in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Nov 2001, 10:16
Newest guidesLatest tool updatesNew media commentsRecent DVD HacksSlysofts AnyDVD HD removes DVD and Blu-ray encryption and region coding. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
