VideoHelp.com Forum
  1. I'm Planning to use a KVCDx2 Template for my movie using TEMPGenc, however when the movie is done converting, I will have a huge movie file that will be ready for 2 CD's. so then what is a simple program to just split the movie in two?
  2. you could demux the mpeg with TMPGenc and then mux with bbmpeg and select the size to split the file under general settings. You could also just cut the file with TMPGenc - (mpeg tools>merge/cut)
  1. planning to buy an appleTV
    By scarlac in forum Video Conversion
    Last Post: 18th Mar 2010, 10:06
  2. apple planning on advertising in its OS
    By deadrats in forum Computer
    Last Post: 24th Oct 2009, 11:59
  3. RipBot Settings - Planning a PC upgrade
    By EdinburghKev in forum Blu-ray Ripping
    Last Post: 26th Nov 2008, 07:01
  4. Replies: 1
    Last Post: 18th Jul 2007, 22:46
