i have a bunch of 720x480 video files i want to put on DVD+R. only 2-3 will fit on a disk at that resolution, so i have used TMPGEnc to change them to DVD low-res (352x240). when i play them on my computer (S-video output to my television) they show up fine -- they play with black bars on the top and bottom, and while the video is somewhat small... it is clear.
the problem is when i burn the same video files to DVD and play them back, they show up fullscreen... which makes the files look very grainy. how can i encode or burn them so they show up with the black bars? i have tried many combinations of settings, but have had no luck... i will be willing to change software if that's the problem -- but i need advice.
i am using DVD Workshop to burn and have chosen both the 720x480 and 352x240 setting... there was no difference in either (i'm guessing that's just for encoding, which it doesn't need to do).
any help on how to get these files so they look like i want them to would be appreciated. thanks!!!!
when using TMPGEnc change your bit-rate instead of the size
When you first open TMPGEnc set your bitrate to 3000kbps and you will be able to get 120 minute on a dvd.
To stop Ulead DVD WS from re-encodeing your footage set your bitrate higher than your mpeg files that you encoded in TMPGEncMichael
Learn to create DVDs the Ezway
DVD Related Question Post them at
www.EzDVDAdvisor.com
DVD Developers Community
i'm not sure your suggestion is applicable as i'm attempting to put almost 5 hours on one DVD. that currently fits... but i just don't want it playing at fullscreen.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Fullscreen vs. Widescreen: why still airing new content in fullscreen ?
By vhelp in forum DVB / HDTVReplies: 56Last Post: 2nd Oct 2009, 14:54 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
Statistics
Newest guides
Latest tool updates
New media comments
