I have done exactly as your guide says ..
I have reached the encoding with TMPGenc . When i was finished with it i open the new movie file [.mpg] , but i didnt here any sound.
(I was doing an SVCD)
[excuse my bad english]
you should separate the sound with virtual hub, them combined the two with tmpge
how ?
http://www.vcdhelp.com/divxtovcd.htm#audio
You need to do this if you have a divx with variable bitrate audio.
what are you doing? ripping a dvd. re encoding another mpg, or avi etc.?
Hi,there is a program called audio decompressor by John schlichther you run your file through this program first which decompreses the audio,then just run through tmpgenc as normal
Okay what they are trying to say is.....
Was the audio in a seperate file or was it in the original video file that you were encoding?
If it was seperate make it a .wav file and put it in the audio option in TMPEG, if it was built in then your doing something wrong
AVI container encoded with H.264/AVC video and PCM sound
By LoLaha in forum Video ConversionReplies: 6Last Post: 20th Mar 2012, 22:14 -
Encoded BD movie sound quality
By GeeForce11 in forum Blu-ray RippingReplies: 0Last Post: 15th Dec 2008, 08:05 -
Video has sound but no picture from encoded avi file. What's wrong?
By Ivor Bigone in forum Video ConversionReplies: 4Last Post: 30th Jun 2008, 10:01 -
DV encoded Sound Problems
By zack28 in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 21st Sep 2007, 18:20 -
no sound on encoded files with MCME
By marukomu in forum Video ConversionReplies: 2Last Post: 20th Jun 2007, 09:05
