Hi all,
I have a Mpeg1-VCD compliant file that I want to use to make a VCD with menus and chapters.
I have mastered the VCD files with TMpegenc adding some critical "I" frame to specific location for my chapter insertion. I have manually added 16 "I" frames.
If I open the file in VirtualDUB, I can see all the "I" frame, and all the ones that I have added are there. VirtualDUB reports a total of 3057 "I" frames (and 15108 "P" and 36038 "B" frames)
When I open the same file in VCDEasy, the "Number of possible entry points" is only of 2540 and none of my manually added "I" frames are in those.
What am I doing wrong ? Since I can't use my manually added "I" frame, my chapters are not properly index and that does not look very professionnal.
Any help/info would be appreciated!
Seeya!
GuestThis has happened to me once as well, when creating a VCD at 23.976fps it didn't let me enter entry points where I inserted I frames. There is no perfect solution, but one that might help: You need to demultiplex your video and then re-multiplex it with BBMpeg. Select VCD stream type, and then "Pad VCD audio" and "Align Sequence headers" and then de-select "Write program end code". This helped me to get some of my manually added chapters, but not all... I have only had this problem once (usually I don't do chapters) so don't know of any better solution...
You need more than just I-frames... There also has to be a GOP header and a sequence header... I'm not entirely sure what TMPGEnc does but it seems that setting it to "close GOPs" can help.
Else, try the suggestion that mpegobsession wrote above.
Regards.Michael Tam
w: Morsels of Evidence
Nero Recode 2 Chapter Mark "Creep" vs. Original DVD
By CobraPilot in forum DVD RippingReplies: 4Last Post: 16th Feb 2012, 22:29 -
In plasma TV "Number of pixels" and "Number of dots" it's not a same term?
By flash_os in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2011, 12:27 -
MPCHC puts a chapter "subtitle" on the bottom of my mp4s
By brianp6621 in forum Software PlayingReplies: 2Last Post: 19th Oct 2009, 12:35 -
Number of possible chapter entry points: 1 - WTF?
By DRP in forum VCDEasy GeneralReplies: 20Last Post: 20th Mar 2008, 18:50 -
Re: making "live" chapter button with windvd creator 2
By tomcat862 in forum Authoring (DVD)Replies: 0Last Post: 28th Feb 2008, 12:13
Statistics
Newest guides
Latest tool updates
New media comments
