I hope someone knows how to fix this problem because i dont have a clue. When i try to burn a SVcd to a cdRW ( cant remember if it does it on Cdrs ) i get this error
"CDRDAO Write" Execution Failed
Write data failed
Writing failed, Buffer under run ?
Writing Failed
Any ideas ?
Thread: CDRDAO failed
ok i have tried it on a cdr and the same thing. I also tried reducing the speed and and increasing the buffer but no joy.
Are you doing anything else on your computer? Don't. Just let it burn until it finishes, or use a different program to burn your bin/cue files. cdrdao does not protect itself from Windows trying to read the CD while it's burning, so doing something like opening "My Computer" will often cause the burn to fail. The same applies to using the drop-down menu at the top of the standard open/save dialog box, since it lists all the drives Windows tries to read all the drives to see what they are and interferes with the burn.
I got this error also..... I just select No CD Writer, and then burn the cue file w/ Nero......
I got it working now. I multiplexed the mpeg in tmpgenc before burning it in svcd and it was find. By the way i didnt know you only had to multiplex mpegs and not put them through that whole hour + process in tmpgenc.
(1) Burn failed !!
By skinney6 in forum DVD RippingReplies: 13Last Post: 4th Feb 2010, 18:01 -
Just installed and failed
By cantthinkofanickname in forum Newbie / General discussionsReplies: 12Last Post: 21st May 2008, 12:20 -
Seek Failed
By zeke1312 in forum Video ConversionReplies: 1Last Post: 20th Mar 2008, 06:59 -
mkv failed @ 90%
By joshmunkey in forum ffmpegX general discussionReplies: 2Last Post: 7th Nov 2007, 18:53 -
Encoding Failed
By hananke in forum ffmpegX general discussionReplies: 5Last Post: 11th Jul 2007, 06:04
