VideoHelp.com Forum
  1. I HAVE A PANASONIC RV20.The problem is i played a vcd burned on a cdrw which worked poorly,however the player will not play normal dvds anymore,have i corrupted the firmware.
  2. Well, you could try to update the firmware. Your settings might be set differently too. Does the dvd match the region of the player? That's something that you should check. You should also make sure you configured the player properly. If it still won't play normal dvds after this, you might have to go buy a new one.
  1. Replies: 6
    Last Post: 5th Feb 2012, 06:58
  2. Replies: 2
    Last Post: 24th May 2010, 05:19
  3. Optiarc DVD RW AD-7240S won't play video dvds
    By cor77 in forum DVD & Blu-ray Writers
    Last Post: 2nd Apr 2010, 02:34
  4. Windows Media Player Won't Play DVDs Anymore
    By Card Shark in forum Newbie / General discussions
    Last Post: 14th Feb 2010, 18:04
  5. HELP! LG RH266 DVD Recorder won't play DVDs!
    By Spudster2257 in forum DVD & Blu-ray Recorders
    Last Post: 28th Dec 2007, 01:26
