  1. Ok, i follow the tutorial and check off "Enable CDRDAO Integration", then i restart. When i open it back up, i get the following error:
    "Unable to perform a CDR devices scan, you may have an ASPI drivers problem."
    What do i need to do?!
  2. no to sure on this program but had a simmilar prob with another program and solved it by downloading and installind the directx 9 from the microsoft site
  3. You need to update your ASPI driver. I use win xp has ver. 4.6 aspi.
    download aspi check and check which ver.. u have use www.google.com for your search.
  1. aspi driver, anyone try this?
    By HatchetMan in forum DVD Ripping
    Last Post: 22nd Jun 2005, 13:10
  2. ASPI driver help
    By ozzhead42 in forum Newbie / General discussions
    Last Post: 23rd Sep 2003, 22:24
  3. ASPI DRIVER
    By sampatman in forum Audio
    Last Post: 6th May 2003, 16:48
  4. no aspi driver problem???
    By j8breakz in forum Newbie / General discussions
    Last Post: 15th Oct 2002, 18:31
  5. what is aspi driver
    By hart42069 in forum Newbie / General discussions
    Last Post: 20th Jul 2002, 01:22
About   Advertise   Forum   RSS Feeds   Statistics   Tools
