VideoHelp.com Forum
Thread: MPEG Error
  1. Hi folks....
    Getting mad.
    I've just encoded some MPGs with TMPGEnc using the standard NTSC template. When I try to use it with teh newest version of VCDEasy I got an error message saying that the MPG file is not correct and that the process cannot start....
    I've been doing it with three different templates of encoding all with the same result.
    I also tried with MPG files encoded with PowerVCR having the same result.
    Any clues??
  2. Guest
    What does it write in the Log?
  3. That the log:
    --DEBUG: changed volume label to `VIDEOCD'
    --DEBUG: changed application id to `'
    --DEBUG: changed album id to `'
    --DEBUG: changed volume count to 1
    --DEBUG: changed volume number to 1
    INFO: scanning mpeg sequence item #0 for scanpoints...
    ++ WARN: mpeg scan: pack header code (0x000001ba) expected, but 0x3c3f786d found (buflen = 688)
    **ERROR: input mpeg stream has been deemed invalid -- aborting
    The version used is VCDWizard 2.6.0.0 release 2.6
    Thanks for the help...
  4. Guest
    Are you sure about the file you are adding, that it is the file you compressed? According to the error log the file you add isn't MPEG file, but XML file (the type of file VCD Easy uses to save information about your project).
    Make sure you didn't overwrite your mpeg files, maybe try using different file names for them. That's what I can think of right now.
    mpegobsession
  5. Solved teh problem dowloading the previous version of VCDEasy. It recognized my MPEG files and generated the image file.
    Sometimes the easiest solutions are really the most obvious
  1. Help on Error Measuremente Mpeg
    By mr_subliminal in forum Programming
    Last Post: 29th Nov 2010, 10:11
  2. QT can't parse error converting mpeg-1 to DV
    By jglass in forum ffmpegX general discussion
    Last Post: 22nd Jun 2008, 10:57
  3. Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
    By jglass in forum Newbie / General discussions
    Last Post: 15th Jun 2008, 20:51
  4. WMV to MPEG gives error
    By tommm in forum ffmpegX general discussion
    Last Post: 21st Dec 2007, 14:46
  5. MPEG-2 Decoding Error
    By shorto in forum Newbie / General discussions
    Last Post: 21st Aug 2007, 15:41
