Hi,
I just burned a few music videos and some skip when i'm playing them. The original file doesn't skip but when I convert them I get this problem. I am using nero 5 to burn. Is there anything I can do to fix this? Any help would be appreciated
Thx,
J
I don't know how much I can help because I'm having the same problem. Do all your video's have the same frame rate? I thought that may have something to do with it but they all have the same one it seems. Some of them don't even skip, they just slow down...I'm also using nero but every time it asked me if I wanted to re-encode or shut off the satndard option I've been shutting it off because the re-encode option always makes the program go weird( i won't be able to right click or burn the cd but it' s not frozen)
-jam tomorrow, jam yesterday, but never ever jam today...()_()
=(6.9)=
Check the bitrates of your mpegs with bitrateviewer. If any of them are higher than the (S)VCD spec allows that may well cause skipping. Other possibility is your DVD player is having difficulty reading the discs. Try a different brand media or burn at a slower speed.
Music Video Vcd Part 2
By vcd4me in forum Video ConversionReplies: 1Last Post: 8th Feb 2010, 14:50 -
Music video vcd
By vcd4me in forum Video ConversionReplies: 11Last Post: 8th Feb 2010, 14:37 -
New music skipping
By Jeikobu in forum Portable VideoReplies: 0Last Post: 24th Jan 2009, 13:13 -
Adobe Premier Pro - Mpg - Skipping.
By primalmedia in forum EditingReplies: 1Last Post: 7th Nov 2007, 10:35 -
Can I burn a music video along with music trax onto the same disc?
By Kalla B in forum Newbie / General discussionsReplies: 0Last Post: 4th Jul 2007, 12:02
Statistics
Newest guides
Latest tool updates
New media comments
