I found some great deals for DVD-R Disks, but am very hesitant, since I'm not sure if the burner will support it. I'm also looking for a good burner. I really like the Pioneer A04, but it's too expensive.
I was wondering, is this any good?:
http://www.toshiba.com/taissdd/produ...002-Over.shtml
Will these disks work on it?:
http://www.shop4tech.com/user.htm?go...&cata=&s_cata=
What Under $250 drive would you recommend? I want a drive that supports the media I posted.
Thanks!
ESbuycom sells the Pioneer 04 for $265.00,that's about the bottom pricewise for DVD burners. AllmediaOutlet sells Princo DVD-R for $0.75 in lots of 50. I find the combo of the Pioneer 04 and Princo disks works very well.
Codec won't work with Vegas
By Jon.G in forum EditingReplies: 1Last Post: 26th Sep 2011, 07:52 -
conversion programs just won't work!
By Sean O'Scare in forum Video ConversionReplies: 19Last Post: 17th Feb 2008, 01:58 -
cd drive rw won't work
By sue1951 in forum ComputerReplies: 6Last Post: 27th Aug 2007, 13:39 -
ffmpegX 0.0.9x r2 just won't work under X.3.9 ?
By Jose Hidalgo in forum ffmpegX general discussionReplies: 1Last Post: 16th Jul 2007, 08:37 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 15:36
Statistics
Newest guides
Latest tool updates
New media comments
