VideoHelp.com Forum
  1. Guest
    Hi,
    I have just made a small program that, at least for me, helps creating VCD stills with audio (background music). I was wondering if, in case of interest, somone could help me test it...
    There are down sides however:
    1) Some manual work is needed for the operation...
    2) It's actually a DOS based program (with all that involves it, like only short file names etc.), but on win2k it runs with no problem, and soon I'll make a win32 based version...
    3) You need TMPGEnc
    Just yesterday, for example, I have made a VCD with over 60min of video and, with the help of my program, also added 130min of stereo audio, all on a 80min CD with no overburning!
    So, in case of interest, reply here and I'll see how I can send it to you or something....
    MPEGOBSESSION
  2. Guest
    Nobody is intereasted?
    Or is this a trust matter?
    MP-OB
  3. Polish it up (I usually have very long filenames) and you'll have something. There is alot of interest in slideshows especially the hi-res still type (as compared to the standard motion VCD MPEG conversions. Maybe add DVD support?
    Panasonic DMR-ES45VS, keep those discs a burnin'
  4. Guest
    It doesn't support DVD as I haven't studied that area yet, but I consider it a very likely future development... In the mean time it works perfectly for me on VCD stills with audio (the high resolution type, 704x576), and later today I'll make my fist test with SVCD type stills with audio...
    As for long file names support, I will add it (along with graphic interface) once I see that people tell me this thing actually works for them...
    mpegobsession
  5. Guest
    Just to note: Tested it and it also works for high resolution SVCD stills.
    mp-ob
  1. Background audio/music
    By web_smurf in forum Authoring (DVD)
    Last Post: 14th Sep 2011, 02:44
  2. How to add background music?
    By coody in forum Audio
    Last Post: 25th Sep 2008, 16:04
  3. help! adding background music
    By Keier in forum Newbie / General discussions
    Last Post: 23rd Jun 2008, 14:30
  4. Replies: 3
    Last Post: 10th Apr 2008, 12:56
  5. How to lower background music
    By auroragb in forum Audio
    Last Post: 24th Jul 2007, 20:54
