VideoHelp.com Forum
  1. Here is what i have just done.
    well you can use TMPGEnc and go to mpeg tools click on simple de-multiplex load your vob file, then go to multiplex load you m2v and ac3 files you just made. once finshed you will have a mpeg file. takes like 7 or 8 minutes for the whole process......
    I am left with an mpeg file but with no sound?
    i am useing real player to play from the hard drive just to test it.
    It trys to update the codecs but says error.
    It does however play it from hard drive yet there is no sound any one know wy?
    so the guy punched me, and later i stole his parrot as way of revenge
  2. If you use TMPGEnc and de-multiplex the .vob file it will not extract the audio, it only extracts the video. Are you sure that you got your .ac3 files from the de-multiplex in TMPGEnc?
  3. that .m2v file you have there part of a SVCD??
    if so, the audio file needs to be mpeg 2 audio file, not .ac3. you need to encode the .ac3 file into mpeg 2 audio file using besweet or toolame.
  4. im going to have to start again dam this is hard stuff to learn.
    thnaks guys im just going to have to use a guide i suppose which is the bet guide for SVCD format and useing only freeware tools?
  1. Can't get sound from MPEG in F.C.
    By Tom in HD in forum Mac
    Last Post: 14th Jan 2010, 22:40
  2. No sound in MPEG
    By 12VIBES in forum SVCD2DVD & VOB2MPG
    Last Post: 17th Nov 2009, 04:54
  3. mono mpeg sound
    By dvdfreak1971 in forum Video Streaming
    Last Post: 20th Apr 2008, 13:41
  4. avi to mpeg -> no more sound
    By myk in forum Video Conversion
    Last Post: 14th Mar 2008, 12:15
  5. there's no sound with my mpeg-1 conversion
    By darealest1 in forum Mac
    Last Post: 13th Jul 2007, 08:12
