once you make a movie mpeg , are you able to put it on vcd ....or are there more steps?...do i need a dvd-rw ??? please reply...anybody
trying to make vcds from downloaded AVI movies
well if you are making vcds all you need cd-r and a burning program such as nero vcdeasy etc....
thanx man....so that is the next step??? and ......i cant use the microsoft burning software??? because i use the media player burning tools......any insight?
What you have is the MPEG... now what you need is a program that will put that MPEG into a VCD format. I'm not positive, but my guess is the Microsoft burning software (what is the official programs name?) burns standard cds only (such as data cds and audio cds). To burn a VCD, get NERO, or VCDEasy ( <- i use this). Both programs are pretty easy to use. If you get lost, you should definately check out the tutorials on this site, they offer a ton of help on the complete process of backing up a DVD, and in your case, how to get them on a CD.
Hope this helps,
Mojo
Step by Step guide for .avi-> vcd/svcd/dvd using ffmpegx?
By kube555 in forum ffmpegX general discussionReplies: 4Last Post: 5th Aug 2004, 19:46 -
what programs to use, and step by step process needed
By eliteconcept in forum DVD RippingReplies: 10Last Post: 23rd Jun 2004, 06:53 -
Need simple, step by step process, PLEASE HELP!
By Sanoske in forum DVD RippingReplies: 3Last Post: 13th Jun 2003, 23:29 -
Need Dumbie Proof Step by Step guide to convert DVD to VCD
By Candace in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2003, 18:10 -
next step in vcd process
By nbfb42 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 5th Jan 2003, 23:56
Newest guides
Latest tool updates
New media comments
About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
