After buring the SVCD the movie image is on the left side surrounded by black.
What did I do wrong?
Dave
Thread: Movie is on the left side
What is your method to make SVCD? Did you demux/remux, cut/join with any software? I used to have that problem if I cut/join/demux/remux any SVCD with any software.
Could be a lot of things...
Did you use TMPG 12c/d?
Could be non-standard resolution?
I had this problem with my apex when i used vcdimager and chapters. if i turned off pbc then it worked fine but then again my chapters and menu would not work so i upgraded the firmware and now sometimes it works and sometimes it doesn't. I know it's the player.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I also own APEX 660 and I used to have the same problem like you do. Everytime I cut/join or demux/remux with TMPGenc even BBmpg I got that problme.
Now I add only "update scan offsets" in xml and create bin/cue with vcdxbuild, the problem's gone.
There is still a problem, though. If I use "resume" function the picture show only half of TV screen.
green or white lines appear on the left side of the viedo when I mux subs.
By shootenPutan in forum Video StreamingReplies: 5Last Post: 31st Jul 2009, 00:53 -
Putting a black frame on left side only?
By gonzo90017 in forum EditingReplies: 5Last Post: 24th Dec 2008, 13:28 -
Faint vertical line on the left side of LCD... normal?
By siratfus in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2008, 03:15 -
I have an AVI voices are in left headphone, music in the right side
By vectoravtech in forum AudioReplies: 14Last Post: 13th Feb 2008, 11:51 -
blue line on the left side
By themaster1 in forum RestorationReplies: 7Last Post: 26th Jan 2008, 08:03
