VideoHelp.com Forum
    Hi together,
    in the last time I get an error message ("Application will be closed...), when I try to convert MPEG1-files to (VCD-compliant) MPEG1 with TMPGEnc2.53 (tested also with old TMPGEnc12a; its the same).
    Under "Details" it said: "TMPGENC caused an error by an invalid page in module LMPGAD.AX with 0177:020419db... bluhbluhbluh...).
    When I demux the source an encode videostream only, it works. (Audio problem?)
    Can anybody tell me what it is and how I can fix it?
    Regards, Mirko
  2. Член BJ_M's Avatar
    LMPGAD.AX is the Ligos MPEG Audio Decoder
    try demuxing your file first or unreg LMPGAD.AX
  1. How to test MPG files for errors?
    By madmartian in forum Software Playing
    Last Post: 17th Jun 2009, 14:30
  2. Replies: 3
    Last Post: 19th Dec 2008, 04:47
  3. Replies: 8
    Last Post: 16th Oct 2008, 13:51
  4. I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
    By emanmb in forum ffmpegX general discussion
    Last Post: 18th Apr 2008, 14:48
  5. Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
    By beetee123 in forum Video Conversion
    Last Post: 27th Jul 2007, 08:47
