So what do you guys think?
Pentium 4
Athalon MP
Athalon XP
What gives the best bang per buck for TPMG and other encoders?
(using the prices from eg pricewath.com)
The AMD XP 2100+ at $85 is the budget sweet spot right now.
http://www.pricewatch.com/1/3/4657-1.htm
A motherboard XP2100+ combo for $130+
http://www.pricewatch.com/1/306/4659-1.htm
Don't forget to set the right settings in BIOS. -
For around $500 you can get a motherboard and dual AMD MP 2000+ processors.
My dual AMD MP 1900+ system generally encodes 740x480 MPEG2's with higher quality settings in TMPGEnc in real time. -
I do not think a dual CPU motherboard gives you most bang for your buck.
A AMD XP 2600+ MB combo with 333mhz frontbus for $360 (and up)
http://www.pricewatch.com/1/306/4979-1.htm
Which Mpeg2 compression codec?
By yugurya in forum EditingReplies: 6Last Post: 20th Jan 2012, 00:35 -
3 dollar voltmeter
By jimdagys in forum Off topicReplies: 1Last Post: 2nd Dec 2011, 21:07 -
Compression technique/standard used in MPEG2 Transport Stream
By digitalmystic in forum Video ConversionReplies: 1Last Post: 1st Nov 2010, 06:50 -
MPEG2 Compression - Question
By b1tbull in forum Video ConversionReplies: 3Last Post: 2nd Jul 2010, 03:14 -
15 trillion dollar tax refund
By deadrats in forum Off topicReplies: 0Last Post: 17th Dec 2009, 09:15
