VideoHelp.com Forum
  1. Hi,
    I have had the error message: ""The found DivX DirectShow decoder (divx_c32.ax) may be incompatible with the current operating system. Please, try to install version 3.11 or 4.0+." popping up each time I want to view a movieclip. I can't figure out what's wrong. Is it something I need?
    (I have Windows 2000 pro swedish).
    Please help me, thanks!
  2. probably you dont got the right codec installed...
    what you need is divx3.11a or 4.11/4.12..
    but try:
    http://www.divx-digest.com/software/nimo_pack.html
    or
    http://www.divx-digest.com/software/acemega_codec.html
    or
    http://www.atlandide.net/~uncasms/de/index.php (and go to downloads to get Tsunami Filter Pack)
    ->those are complete codec packets, that come with all the stuff you'll need
  3. I installed both Nemo ACE and it worked
    But, I also tried installing the Tsunami filters and the shit was writing over some WINNT\SYSTEM32 files and now I can't get no picture of any movies in any of my players anylonger :/
    What shall I do?
  4. I removed the Tsunami filter and ACE. And reinstalled ACE again, now it works. Should I reinstall the Tsunami filter again, and if so, why?
  5. no, install only 1 of the filterpacks, otherwise, they'll "bite" each other... (sorry for my incomplete description)
  1. Help. Avisynth Error Message "no function named limitedsharpen"
    By Pitorasilo in forum Video Conversion
    Last Post: 27th Dec 2010, 06:13
  2. Help. Avisynth Error Message "no function named deblock"
    By hypnoticpimp in forum Video Conversion
    Last Post: 27th Sep 2008, 23:45
  3. DVD Flick error message "ffmpeg.exe has stopped working"
    By stewiegriffin711 in forum Authoring (DVD)
    Last Post: 17th Aug 2008, 07:20
  4. Divx Player Error "NO Recorder Found"
    By vitonxl in forum Software Playing
    Last Post: 21st Jan 2008, 21:34
  5. Replies: 1
    Last Post: 27th Jun 2007, 01:16
