DVD Photo Slideshow enables you to make use of your CD burner to create exciting photo albums that are playable on TV with standard DVD or VCD player. It optimizes your digital photos and uses the High Resolution Still Picture format which is supported by DVD/SVCD. This technique makes photos look great on TV.
You need to download the DVD Photo Slideshow 1.0 trial version from http://www.dvd-photo-slideshow.com and install it. After successfully launch DVD Photo Slideshow, you can follow four simple steps to create and organize your photo albums, set disc menu, preview your photo albums, burn your photo albums on a blank CD-R or CD-RW disc. Then, you can enjoy your creative works on TV through a DVD/VCD player.
1. Create and organize Albums: Click the Editor toolbar to create photo albums and select photos from a folder on your hard drive and add them to a particular album.
2. Set Disc Menu: Click the Disc Menu toolbar to Select a template of disc menu which decides how the photo album will be shown on your photo video CD. You can edit the photo CD menu by adding your favorite background music in WAV or MP3 format and background image in JPEG, JPG, TIF, GIF, BMP etc format to the selected disc menu.
3. Preview your photo albums: Click the Preview toolbar to preview your slide show. With the simulation of a TV and a DVD player remote control, you can view your photo album exactly as what you will watch photo on TV with DVD or VCD player.
4. Burn photo albums to CD: Click the Burn Now toolbar to burn your photo album to a blank CD-R or CD-RW disc.
Results 1 to 1 of 1
DVD Photo Slideshow
By jet757f in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2010, 12:54 -
DVD Slideshow - my Still photos Flicker.
By CP/M User in forum Authoring (DVD)Replies: 11Last Post: 26th Mar 2010, 20:29 -
Using Magix Photo Story CD/DVD 8 to compile photos
By Surber in forum Newbie / General discussionsReplies: 1Last Post: 24th Jan 2010, 19:08 -
Burn photos slideshow into a disc–what’s the difference between DVD and CD?
By coody in forum Authoring (DVD)Replies: 5Last Post: 12th Oct 2008, 22:24 -
Any easy tool to make a DVD photos slideshow with the background?
By coody in forum Authoring (DVD)Replies: 9Last Post: 27th Sep 2008, 14:34
