I am currently using a software called CoverXP to print out covers and labels from cdcovers.cc . The dvd labels work great, but for some reason, every time the DVD covers print out, the printer doesnt print the last 1" or so of the cover. I hear it is something with the options with CoverXp, but can't figure it out. I would really appreciate any help! Thank you soo much!![]()
Thread: DVD Cover Software! CoverXP
You probrably have your margins set too big on the paper. I dont know about coverxp as I use paintshop pro to print my DVD covers, but if you decrease the margins on the page it sould print all of the cover.
[use latest Nero cover designer... very easy to use...]
I dont know anything about that CoverXP, but when you print could you open printer options before actually printing anything? for example in Epson stylus photo you can set maximum printing area there(and orientation portrait/landscape!)...
Zzzzzzzzz
Try this one, itīs a freeware
http://www.grafxfreeware.homestead.c...overprint.html
It has a search function that connects you to cc.covers, and prints VHS snd CD besides DVD
The only solution:
FuknPrint!
Its freeware. Connects to the CD.Covers server, loads up the front middle and back, Sizes perfectly. Just hit the print button. Over 3500 covers. I use it all the time. It rocks.
VidHAck
for coverxp just change the paper size to legal on printer properties and use legal paper and they look beautifull
hopes you can make it..
good luck................
You forgot to tell them where to find FuknPrint!Originally Posted by VidHack
http://www.fukrulez.com/index2.php
I have a new version of FukNPrint coming out soon. FukNPrint 3.0 is now in Release Candidate 1. It is a 14 day Test Version, in case bugs are found. The Official 3.0 version will be out on January 7, 2003. I added Lots of new functionality.
For one support to opena and print files from shelling the app and file from command-line.
Added various file format support, such as PSD, TIFF, PSP, SGI, and other.
Added Print Resolution.
More settings, can be saved.
Better Logging.
Added Several Hundred New Covers, over the past week.
Added Covers Needed Addon (Keep a list of movies you need covers for (search for them it will automatically update the list as you print them.
Added Image Tool to support Resize, Rotate, and Crop functionality.
Speed up routines for downloading, since old versions USE mainly FTP Transfer.
Ensure it is up to date, just as Other software such as DVD Decrytper. LiveUpdate optionally be called when updates are available.
Better LiveUpdate Engine.
PRICE:NOTHING. Yep, I said Nothing.
(I however do not put banner adds In my software when I say PRICE:NOTHING)
Software for guys to backup movies, from guys who backup movies
thresher
CD Jewel Case Cover Creating software....
By SE14man in forum Newbie / General discussionsReplies: 6Last Post: 16th Jul 2011, 16:17 -
cover design software
By butterflies in forum Authoring (DVD)Replies: 17Last Post: 26th Jan 2010, 00:56 -
DVD cover software
By Prot in forum MediaReplies: 6Last Post: 3rd May 2009, 23:38 -
Different AR on IMDb and DVD-cover
By tominator in forum Newbie / General discussionsReplies: 4Last Post: 26th Mar 2008, 07:47
