Still problem with "Writing failed - buffer under run?" Anyone PLEASE!
Here is my log.......
[CDRDAO Write]
WARNING: During writing you should avoid to open the Windows Explorer and similar tools
WARNING: CDRDAO does not lock the recording device so that all access action from the Explorer will lead to a failure of the recording process.
Cdrdao version 1.1.7
1,1,0: LITE-ON LTR-52246S Rev: 6S07
Using driver: Generic SCSI-3/MMC (raw writing) - Version 2.0 (options 0x0000)
ERROR: Try again first, then
WARNING: Length of toc (83:08:21, 374121 blocks) exceeds capacity of CD-R (79:57:74, 359849 blocks).
WARNING: Ignored because of option '--overburn'.
WARNING: Some drives may fail to record this toc.
Starting write simulation at speed 2...
Turning BURN-Proof on
Using 16 byte P-Q sub-channel data mode.
Writing lead-in and gap...
Writing track 01 (mode MODE2_RAW/AUDIO )...
Writing track 02 (mode MODE2_RAW/AUDIO )...
cmd finished after 3.410s timeout 20s
ERROR: Write data failed.
ERROR: Writing failed - buffer under run?
ERROR: Simulation failed.
Results 1 to 1 of 1
problems with CD burner xp
By marlo in forum AudioReplies: 3Last Post: 2nd Oct 2010, 06:35 -
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 10:55 -
DVD burner problems
By coody in forum DVD RippingReplies: 5Last Post: 12th Sep 2008, 00:18 -
Problems with DVD Burner
By poppy56 in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jan 2008, 22:48 -
Problems with Toshiba laptop burner
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 10th Sep 2007, 23:42
