I need some help!!!! First I had an .avi file. I put this thru the TMPGE.....exe (after doing the virtual dub to get the fps and a seperate .wav file), and i ended up with a .mpeg file. Next was VCDeasy. Started this fine, then got to what I think was the write(burn) part and got this error. CDRDAQ write execution failed - Power calibration failed - writing failed. Can any one tell me what I am doing wrong????![]()
Its ok - I worked it out - I turned the write speed doen to 2 and it worked like a dream - but am having a bit of trouble with the sound. Its all in sync, but there is a humming noise thru the entire movie - Is this normal???
BD Rebuilder: ERROR "failed video encode, aborted"
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 22nd Feb 2011, 18:57 -
What is the problem when it says "failed video encode, aborted "?
By PERSHON in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 12:33 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 17:50 -
ATI AIW 9600XT, "TV failed to initialize the video" problem...
By etecnifibre in forum CapturingReplies: 11Last Post: 20th May 2008, 15:08 -
failed to connect Output pin 0x0093ae4c ["Stream 00"] on AVI Spli
By carcrashhearts in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 12:46
Statistics
Newest guides
Latest tool updates
New media comments
