Hi, I'm a complete newbie to this whole video thing....and in one movie I was able to fit it on a 700 MB CD. Actually, I had to save it as a data CD, because when I tried to burn it as a VCD, it said it wasn't encoded into the proper VCD format or something like that (I used that guide for how to fit your movie onto one CD using TMPGEnc 2.58)
Anyways, now I have another movie that I want to put on a CD, but I want to learn how to make it be able to rewind and fast forward because my other movie couldn't do that. I don't know if it's because I saved it as a data CD or not, I don't know if that's the case or not, but any help would be appreciated. Bear with me, I'm new.![]()
Thread: Rewind/Fast forward
Yes, the reason why it wouldn't rewind or fast-forward was because you had burnt it as a Data CD (or CD-ROM ISO). You need to burn it as a VCD and it should be rewindable and fast-forwadable.
Hope That Helps!!!
:P
Well at least now I know it was because I had saved it as a data CD, but now I would like to know how do I burn it as a VCD, if everytime I tried burning it, my software would say it wasn't encoded into the correct VCD format??
I used TMPGEnc 2.58 to encode it to fit on a VCD (non-standard) or something like that, using the guide that's on this website.
Thanks for the help.
This is what you need to do so Nero can accept your files:
1. Launch Nero.
2. Close the Wizard.
3. Select File->New, then Select VideoCD.
4. Uncheck "Create standard compliant CD" under VideoCD and click on new.
You should now be able to burn your files and play them back on your DVD Player.
Hope That Helps!!!
:P
AviDemux Fast Forward and Rewind
By MJS in forum EditingReplies: 2Last Post: 2nd Feb 2011, 06:16 -
Sumvision Phoenix will only fast forward or rewind some files.
By muay in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jan 2011, 07:01 -
Joining FLV videos -- playback problems with rewind/fast forward
By gumbygum in forum EditingReplies: 0Last Post: 30th May 2010, 15:32 -
How to Enable a Title for Fast Forward - Rewind?
By Nocturne in forum Authoring (DVD)Replies: 3Last Post: 27th Jun 2008, 23:46 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 21:48
Statistics
Newest guides
Latest tool updates
New media comments
