VideoHelp.com Forum
  1. loveo
    When I convert Real Player files to Avi/Divx or VCD files , i have problems about out of synch.
    And , i would like to have some details to correct video quality.
    PS : Excuse me for my english but i'm french.
    cya
    <font size=-1>[ This Message was edited by: kenjiro59 on 2001-08-27 09:25:01 ]</font>
  2. From the TinraGUI support forum:
    This is an audio / video sync issue. It results because RealMedia clips are encoded using variable frame-rates and AVI clips are encoded using a constant frame-rate. Many different programs have ways of fixing this, but here's the method that I like best:
    Using VirtualDub, choose direct stream copy from audio and video pulldown menu's in VirtualDub, and under video - frame-rate, choose "change so video and audio durations match". Now Choose File - Save AVI and save to a synced AVI.
    This just syncs the file. If you want to compress the file to a smaller format at the same time, instead of choosing direct stream copy from the audio and video drop down menu's, you can choose full-processing and set the compression options you want...
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
  1. Question about settings for convert movies in divx/xvid to m4v or mp4
    By Marcelo_Ramone in forum Newbie / General discussions
    Last Post: 12th Sep 2011, 09:25
  2. Convert movies from my ipod touch to PS3 and DVD Player
    By d_unbeliever in forum Video Conversion
    Last Post: 13th Jun 2009, 06:05
  3. Convert DivX movies to 480x234 for portable dvd.
    By balagan in forum Portable Video
    Last Post: 9th Feb 2009, 14:03
  4. Replies: 6
    Last Post: 20th Oct 2007, 16:11
  5. Convert movies for a settop DVD player?
    By harleytio in forum Newbie / General discussions
    Last Post: 6th May 2007, 16:05
