VideoHelp.com Forum
Thread: fps meaning
  1. how does a digital capture have frames per second? what would the difference between 10fps and 20fps be in a capture? i thought digital video didn't have frames?
    and another question regarding quality. does image size necessarily determine quality? or is it just a small part of the whole.
    thanx
    12twelve12
  2. Member holistic's Avatar
    thanx
    12twelve12
    Digital capture ?? - lets assume you meant camera
    - For the cheap webcam/cameras 15 fps is the norm. (they are designed that was because of bandwith limitations on usb1.1)
    - For digital 'still' cameras with motion capture a similar problem exists - lack of storage to do full motion
    - For your standard DV camera there are adjustable shutter speeds do not confuse this with frames per second. Digital video will have frames according to its standard - ie PAL = 25 fps
    regarding quality - image size doesn't necessarily quality BITRATE does - for the same frame size , say 720*480 a bitrate of 8000 will look better than 1150 (exagerated)
    An easy way to prove this - scan a small picture (100 * 100 pixels) at 50 dpi the the same one at 600 dpi. Now enlarge both (you won't need to enlarge the 600 dpi one ) to 400*400 . Notice the pixelization. Less DPI = less bits
    i hope this answers your question
  3. so digital video does capture with frames, just like film?
  1. the meaning of various tunings in x264
    By codemaster in forum Video Conversion
    Last Post: 15th Mar 2012, 09:49
  2. Meaning of error message presneted by eac3to
    By Mr Davo in forum Blu-ray Ripping
    Last Post: 6th Feb 2011, 23:55
  3. Replies: 6
    Last Post: 17th Nov 2010, 22:42
  4. Sync 29.970 FPS audio to 23.976 FPS video?
    By LCO1971 in forum Newbie / General discussions
    Last Post: 13th Sep 2008, 15:23
  5. How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
    By Chuba753 in forum Newbie / General discussions
    Last Post: 6th Jun 2008, 19:17
