VideoHelp.com Forum
  1. Can I use a program like vcdeasy to burn both VCD2.0 (still images) and SVCD (mpeg2 video) on the same disk?
  2. Guest
    Why would you like to do that? You want to use existing VCD2.0 stills?
    I think that it will accept it, but in any case, try burning it on CD-RW first to see if your DVD supports it...
    mpegobsession
  3. If you make a SVCD, you should use SVCD formatted mpeg still images which VCDEasy can also make.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  4. thanks to all that replied.
    I have a player that does not seem to display SVCD stills correctly. It does display stills in vcd2.0 format. Obviously, I want to build a disk that has some SVCD video and stills together.
    I'll try the vcdeasy software some more.
  5. Okay, you should be able to try VCD2.0 stills... Be aware you are making an XSVCD then...
    Best of luck.
    Regards.
    Michael Tam
  1. VCD to DVD (not SVCD)
    By noyou in forum SVCD2DVD & VOB2MPG
    Last Post: 19th May 2009, 16:56
  2. How to make a VCD/SVCD with CD Audio (CDDA)
    By Baldrick in forum User guides
    Last Post: 24th Dec 2007, 18:37
  3. Beeping on vcd/svcd
    By mgdt in forum Newbie / General discussions
    Last Post: 20th Dec 2007, 10:56
  4. avi to vcd/svcd
    By neynme in forum DVD Ripping
    Last Post: 26th Aug 2007, 20:25
  5. How to copy-protect a VCD/SVCD v2.0
    By Sine29 in forum User guides
    Last Post: 20th Jul 2007, 10:27
