I am looking for help on purchasing a good DVD Player. I want one that will play VCD and SVCD. I also want one that will play DVD+R/RW and DVD-R/RW. And of course CDR and CDRW. I don't want to spend to much, but money is not the factor here. Let me know you recommendations. Thanks in advance.
Vincent
Thread: DVD Player Purchase Help
Wow thanks for the non helpful post. I went through this, but since most people don't post correct information it is not very helpful. I have a JVC right now and according to the DVD Player list it plays all the DVD recordable media. Guess what, it does not. So if anyone else out there can make a good recommendation, I would appreciate it.
Thanks,
Vincent
That's the exact answer I would have given you. You ask about DVD Players you get refered to the DVD Player list, it only makes since.
Think about what you said. The same people who post there, post here. Plus, at least that list is updated and checked. So go by what the list says and try them out for yourself at the store. Then you're sure to get the options you want.Originally Posted by vincentw56
Maybe its a different serial, or you had a bad disk. If people test a player and it works they add it. They call it as they see it, so if you have variables that are different from theirs your outcome maybe different. Don't knock the list because of one flaw, when operator error could always be factored in.Originally Posted by vincentw56
I had the same problem. My Pioneer player was listed as playing different disks, but nothing worked for me. I went to Wal-Mart and bought that el' cheapo Apex AD-1100W for $50. It's played every disk I've made so far. Generic CD-RW, Generic DVD-RW, Verbatim DVD-R, Memorex DVD+RW, Sony DVD+RW, and the $0.95 Accu DVD-R from Meritline.com
And, if it doesn't work for you, wrap it back in the plastic and take it back to Wal-Mart for a refund.
Bob
My burner is the Sony DRU-500A
Thanks for the response. From what everyone is saying is that the Apex's are pretty good a playing just about everything. I will keep trying. Of course, I cannot find the 1100's anywhere.
L8r,
Vincent
The only thing I have tried that Apex didn't take were Panasonic DMR-HS2 burned disks. I'm happy with my Samsung 711 though.
Please suggest a simple portable USB DVD burner to purchase in the US
By suirauqa in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Jun 2010, 07:49 -
Want to purchase good DVD Upconverting 2.0 USB Player in Canada
By scharfg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Jan 2010, 23:50 -
Advice needed in a VHS/DVD recorder purchase
By higgins327 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 14th Aug 2008, 15:44 -
Purchase New Movies on iTunes Same Day as DVD Release
By Epicurus8a in forum Latest Video NewsReplies: 0Last Post: 1st May 2008, 15:08 -
If I purchase a low end DVD player just to watch movies....
By leftyloopy in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Feb 2008, 14:02
