has anyone done this ?
i have 1.1.2 and there is something that says rip and it shows some of the icons but it looks like it would rip it to a file, and not extract that actual mpeg....any help would be good thanx
Thread: VCD rip with VCDEasy
It's been a while since I did this, but it can extract the MPEG and related files, plus give you an XML file to recreate the image. You'll also get a bin/cue pair along the way, since the vcdimager back-end tool that extracts the MPEG works with bin/cue files.
hmm i dont understand how to do it still....
can you tell me step by step? lol please?
thanx
Make sure you have VCDEasy set up to use your CD-ROM or CD-RW. Put the VCD in whatever drive you have set up in Settings->CDRDAO.
Go to Tools->(S)VCD Build/Rip. Under vcdxrip select CD Reader or CD Writer, depending on your cdrdao settings and which drive you put the disc in.
Click "XML file". Navigate to a directory and save the XML file. Click "Rip". All the files will end up in the directory where you saved the XML file.
hi,
im new to ripping vcds but i used the VCDGEAR GUI to rip into mpegs. I put in my vcd movie in my cdrom and then extracted the mpegs from there into VCDGEAR GUI. I created a new folder to put the mpegs in there. I then used VCDEASY to burn to CD-R. in the VCDEASY all you need to do is find your mpeg files and add them where it says MPEGS/ PICTURE FILES. That is how I have done mine. My vcd movies playback on my standalone apex dvd players and my shinco portable dvd. To some it maybe a longer way of doing it but it works for me. Like I said I am new to this and I am learning more as I go along the way.
Rip VCD to ISO without converting
By cynikalhedonist in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Mar 2011, 12:50 -
Rip audio from VCD
By miamicanes in forum AudioReplies: 9Last Post: 4th Aug 2010, 08:04 -
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 14:11 -
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 06:40 -
help rip vcd
By Mjzchild in forum Authoring (VCD/SVCD)Replies: 1Last Post: 28th Jun 2007, 02:39
