Hi!
Whenever I try to watch an original dvd movie directly from the player or any kind of mpeg2 movie (DivX) from the HDD, I get the same type of error from the player (software). I have tried full versions of Intervideo WinDVD4, PowerDVD 4.0, DivX PLayer 2.0 Alpha and Windows Media Player for XP (8.0).
The error messages are:
Windows Media Player:
Create Overlay failed. Please lower your screen resolution or color depth and try again
PowerDVD:
PowerDVD does not support the current display mode. (DDraw Overlay mode is recommended)
Please lower the screen resolution and color depth, for example, 800x600 with 256 colors.
Or you may adjust the refresh frequency, for example, to 75 Hz.
- which does nothing for me when I try it.
I tried updating the nVIDIA drivers, but I rather suspect it is a DirectX error, since DirectXDiag says:
DirectDraw Acceleration is not availlable (but the test works fine).
Direct3D Acceleration is Enabled, but trying to test Direct3D gives the following error message:
"Direct3D test results: Failure at step 8 (Creating 3D Device): HRESULT = 0x8007000e (Out of memory)"
Can anybody please help me find a solution to this problem?
The whole box is hardly a month old, it is freaking me out!!![]()
thx -
Z-Com
http://ztatic.net
I have wxp sp1 installed, which integrates directx 8.1
Z-Com
http://ztatic.net
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 12:40 -
Nero Error Msg - 'Prepare Session Failed'
By Dieseldog in forum Authoring (DVD)Replies: 0Last Post: 19th Dec 2011, 07:38 -
How to create edited DVD that will play on standalone player with menus
By bahjan in forum User guidesReplies: 0Last Post: 26th Mar 2011, 15:39 -
error writting failed, exception 8, status 31 text'CstarBurn_ScsiTransport
By raiden68 in forum Authoring (DVD)Replies: 6Last Post: 6th Feb 2010, 01:39 -
FAVC - Error (Fix VTS Sectors failed!)
By tim_ver in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2009, 02:16
