VideoHelp.com Forum
  1. I have some mpegs in VCD format that I KNOW are ok because I've burned them and they are fine on my DVD players and they previously played fine.
    But recently they seem "speeded up" especially if I jog through them a bit. Anyone else ever had this problem?
    I've downloaded a few codecs required for some recently obtained movies but I'm not sure if that is the culprit.
    You've probably changed the framerate when you encoded your VCD. Check to see what your source file framerate is.
  3. But VCD I recorded months ago are also doing it.
    When I burn them onto a CDR and play them in a DVD player they are fine. But when I play the mpegs on widnows media player they are screwed up.
    This is happening to all my mpegs, which a week ago, all played fine.
    When I burn them onto a CDR and play them in a DVD player they are fine. But when I play the mpegs on windows media player they are screwed up.
    note the bold word, there's your problem, i have a similar problem sometimes, only mine's with audio, and it in turn speeds up the whole movie, usualy if i reboot and just go straight to watching the movie it'll work at normal speed, if not, partition your HD back up all your files and reinstall windows.
    Derek
    get a real keyboard, Kinesis
  5. Guest
    I had the same problem in windows, and it started right after I installed Ulead DVD-Workshop. I think that it is caused by the direct-show filters that it added, the ones by LSX. I stoped using it after I instaled another program that changed the filter that is used for MPEG playback.
    Is there any program you installed recently afterwhich this problem started?
    mpegobsession
  1. Speeding Up Editing.
    By vodmare in forum Newbie / General discussions
    Last Post: 3rd Sep 2010, 14:13
  2. Speeding Up / Clean Up on XP
    By tgpo in forum Computer
    Last Post: 7th Sep 2009, 20:09
  3. Speeding Up Video...
    By ufcdanny in forum Editing
    Last Post: 29th Jul 2008, 02:41
  4. Problems speeding up a clip
    By dddub in forum Editing
    Last Post: 21st Feb 2008, 17:11
  5. Speeding up Audio, When would I do it?
    By Hittz in forum Audio
    Last Post: 19th May 2007, 17:27
