I am amazed at how easy VCD is to use and setup.
BUT, when playing back the burned image on a DVD player the motion is choppy or start/stop. Its like alternating between hitting the pause and play button when its playing.
I am doing this on a fast AMD 1ghz 256k Ram, 15gigHD (7gig free) with no other apps running so I don't see what the problem is. Also, HP 8200 CD Writer.
Anybody know?
Thread: Playback choppy
This problem may have happened because of the framerate of your source file, the wrong field order, or burning at a very high speed.
I'm not sure about the source someone else created the mpeg.
But the speed too fast? no, its a 24x 4x 8x or something like that. Its a slow burner compare to todays standards.
alan93, what burn speed do you usually burn your VCD's with?
well the max speed of the burner is 4x, so I guess 4x. What do you mean?
24 is your writting speed but you can use settings below this (recommended for a better quality burn) x 4 this is your re-writting speed ( on cd-rw discs) and x8 is the read speed, i assume that's a typo and you meant 48... witch should be more then fast enough to read a vcd
Derekget a real keyboard, Kinesis
alan9 wrote that he had choppy playback. I have the same symptoms on my DVD player when playing recently created SVCDs which happen to work fine on my PC. VCDs and even some SVCDs I created last year work fine on both the PC and the DVD player. I cant remember what settings I used to make the successful SVCDs though. could the quality of the CD-Rs have anything to do with it?
I haven't figured out my problem for sure yet but I'm betting that my 15 gig HD that's half used up is part of the problem. Need bigger I'm sure.
As for quailty of CDRs I made some music CDs with some cheapo disks and they don't track half as good as the Memorex I used first.
So I would bet using a HD over 40 gig and higher quality disks would be a step in the right direction.
Choppy Playback
By allycat in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2005, 12:44 -
choppy playback on T.V.
By zachdank in forum Newbie / General discussionsReplies: 4Last Post: 30th Aug 2004, 09:55 -
Choppy playback on PC, but ok playback on standalone
By mikeyboy in forum Authoring (DVD)Replies: 1Last Post: 20th Feb 2003, 05:58 -
choppy playback
By kangaroo in forum Newbie / General discussionsReplies: 2Last Post: 19th Sep 2002, 14:14 -
Choppy playback on stand alone dvd player. PC playback is ok
By landes in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2002, 20:23
