I am amazed at how easy VCD is to use and setup.
BUT, when playing back the burned image on a DVD player the motion is choppy or start/stop. Its like alternating between hitting the pause and play button when its playing.
I am doing this on a fast AMD 1ghz 256k Ram, 15gigHD (7gig free) with no other apps running so I don't see what the problem is. Also, HP 8200 CD Writer.
Anybody know?![]()
Thread: Resulting playback bad
woops sorry , i didn't know there was a playback forum.
Hi there from a fellow-dvd to vcd fan.
Various of things can cause choppy playback:
Most commonly is bitrate settings that are too high, out of specs.
ea: VCD must be cbr of 1150 and audio 224
If you change that, it will play choppy. On cvd and svcd, remain max under 2520kbs.
If you use 3:2 PULLDOWN IT CAN ALSO CREATE CHOOPY and jerkiness.
Ensure your dvd player supports the format you are trying toplay
Visit this great site where you can download some real amazing templates for TmpGenc!! (Or any encoder)
Proven templates with the highest quality possible before Dvd.
Settings that work. No lies about fitting a dvd to 1 cd-r!
Get real results with tested templates. CVD works unbelievable.
Get no blocknoise and learn more tricks to remove artifact in backgrounds.
PLUS loads of free downloads and some more real cool deals!
Hope to see you visit "The DV-Basket" soon!!!!
Click here: http://www.creativedimension.co.za/m...ostor/info.htmPlenty answers and downloads from http://www.creativedimension.co.za/m...ostor/info.htm
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad .vob .mpg file playback, colors messed up
By lindylex in forum EditingReplies: 2Last Post: 30th Dec 2009, 09:56 -
bad playback mini DV tape
By izzykatz in forum Newbie / General discussionsReplies: 4Last Post: 15th Aug 2009, 14:20 -
Playback is bad
By AMark in forum DVD & Blu-ray RecordersReplies: 7Last Post: 3rd Feb 2009, 12:00 -
Using HCenc in AVI2DVD, but no resulting MPG?!?
By blizzery in forum Video ConversionReplies: 4Last Post: 23rd Jul 2007, 13:49
Statistics
Newest guides
Latest tool updates
New media comments
