The problem is I have a movie that when people talk (Chinese) it only comes from the left side, but the other sounds seem 2 come from both, Is there any way 2 fix it?
Thread: Sound from left side?
That's not really a problem.
A lot of Chinese movies (vcds) have a dual language mode. So the sound is in mono, not stereo. The left side is in one language and if you switch to the right side, it will be in a different language. If you do both sides, then you get both languages at the same time. So just pick a side and commit.....
I c then Im stuck with only hearing the sound from 1 side then, thanks 4 the info. 2 bad I cant edit it some way 2 make it come from both side
green or white lines appear on the left side of the viedo when I mux subs.
By shootenPutan in forum Video StreamingReplies: 5Last Post: 31st Jul 2009, 00:53 -
Putting a black frame on left side only?
By gonzo90017 in forum EditingReplies: 5Last Post: 24th Dec 2008, 13:28 -
Faint vertical line on the left side of LCD... normal?
By siratfus in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2008, 03:15 -
I have an AVI voices are in left headphone, music in the right side
By vectoravtech in forum AudioReplies: 14Last Post: 13th Feb 2008, 11:51 -
blue line on the left side
By themaster1 in forum RestorationReplies: 7Last Post: 26th Jan 2008, 08:03
Statistics
Newest guides
Latest tool updates
New media comments
